[GRASS-dev] making grass modules less verbose
Sören Gebbert
soerengebbert at gmx.de
Wed Sep 20 03:37:36 EDT 2006
i think this is a nice idea.
Some modules are very verbose and with this approach a general
way is provided to handle this verbosity.
Best regards
Soeren
Jachym Cepicky schrieb:
> Hallo,
> following patch makes GRASS modules able to use --verbose flag or set
> GRASS_VERBOSE environment variable.
> In the code:
> if (module->verbose)
> printf("Blah, blah, blah, blah\n");
> or
> G_percent(row, nrows, 2);
> I thing, that according to Eric Steven Raymond, if the program does
> not have anything interesting to say, it should say nothing. This is
> good for embeding GRASS in some web server application or for some scripts.
> But how to use it in old GRASS modules, so that the number of modules,
> which must be corrected by hand, is as low as possible? Do you thing,
> this is useful? Shall I put apply this to cvs?
> Example session:
> GRASS 6.3.cvs (spearfish60):~ > export GRASS_VERBOSE=0
> GRASS 6.3.cvs (spearfish60):~ > r.example --help
> Description:
> My first raster module
> Keywords:
> keyword1, keyword2, keyword3
> Usage:
> r.example [-q] input=name output=name [--overwrite] [--verbose]
> Flags:
> -q Quiet
> --o Force overwrite of output files
> --v Verbose module output
> Parameters:
> input Name of input raster map
> output Name for output raster map
> GRASS 6.3.cvs (spearfish60):~ > r.example in=aspect out=aspect
> GRASS 6.3.cvs (spearfish60):~ > r.example in=aspect out=aspect --v
> 93%
> GRASS 6.3.cvs (spearfish60):~ > export GRASS_VERBOSE=1
> 93%
> Looking forward to your comments
> Jachym
> Index: include/gis.h
> RCS file: /home/grass/grassrepository/grass6/include/gis.h,v
> retrieving revision 1.33
> diff -u -r1.33 gis.h
> --- include/gis.h 19 Aug 2006 12:52:21 -0000 1.33
> +++ include/gis.h 19 Sep 2006 14:43:42 -0000
> @@ -570,6 +570,7 @@
> char *keywords; /* Keywords describing module */
> /* further items are possible: author(s), version */
> int overwrite; /* overwrite old files */
> + int verbose; /* print all informations about progres and so on */
> struct TimeStamp
> Index: lib/gis/parser.c
> RCS file: /home/grass/grassrepository/grass6/lib/gis/parser.c,v
> retrieving revision 1.85
> diff -u -r1.85 parser.c
> --- lib/gis/parser.c 17 Sep 2006 21:50:00 -0000 1.85
> +++ lib/gis/parser.c 19 Sep 2006 14:43:43 -0000
> @@ -136,6 +136,7 @@
> static int n_opts = 0 ;
> static int n_flags = 0 ;
> static int overwrite = 0 ;
> +static int verbose = 0 ;
> static struct Flag first_flag; /* First flag in a linked list */
> static struct Flag *current_flag; /* Pointer for traversing list */
> @@ -171,6 +172,7 @@
> static int split_opts();
> static int check_multiple_opts();
> static int check_overwrite();
> +static int check_verbose();
> static int interactive( char *);
> static int interactive_flag( struct Flag *);
> static int interactive_option( struct Option *);
> @@ -728,6 +730,12 @@
> overwrite = 1;
> + /* Verbose option */
> + else if ( strcmp(ptr,"--v") == 0 || strcmp(ptr,"--verbose") == 0 )
> + module_info.verbose = 1;
> /* Force gui to come up */
> else if ( strcmp(ptr,"--ui") == 0 )
> @@ -794,6 +802,9 @@
> if ( check_overwrite () )
> return -1;
> + if (check_verbose ())
> return(0) ;
> @@ -932,6 +943,10 @@
> len=show(item,len);
> + strcpy (item, " [--verbose]");
> + len=show(item,len);
> fprintf (stderr, "\n");
> /* Print help info for flags */
> @@ -960,8 +975,9 @@
> if (new_prompt)
> - fprintf(stderr," --o %s\n", _("Force overwrite of output files")) ;
> + fprintf(stderr," --o %s\n", _("Force overwrite of output files")) ;
> + fprintf(stderr," --v %s\n", _("Verbose module output")) ;
> /* Print help info for options */
> @@ -1334,9 +1350,10 @@
> if (new_prompt)
> fprintf(stdout, " [--<b>overwrite</b>] ");
> + fprintf(stdout, " [--<b>verbose</b>] ");
> fprintf(stdout, "\n");
> @@ -1371,6 +1388,10 @@
> fprintf(stdout, "<DT><b>--overwrite</b></DT>\n");
> fprintf(stdout, "<DD>Force overwrite of output files</DD>");
> + fprintf(stdout, "<DT><b>--verbose</b></DT>\n");
> + fprintf(stdout, "<DD>Verbose module output</DD>");
> fprintf(stdout, "</DL>\n");
> @@ -2144,6 +2165,34 @@
> return(error) ;
> +/* Check verbose */
> +static int check_verbose (void)
> + char *verstr;
> + int verb;
> + verb = 0;
> + /* Check the GRASS VERBOSE variable */
> + if ( (verstr = G__getenv ( "VERBOSE" )) ) {
> + verb = atoi ( verstr );
> + /* Check the GRASS_OVERWRITE environment variable */
> + if ( (verstr = getenv ( "GRASS_VERBOSE" )) ) {
> + if (atoi ( verstr ))
> + verb = 1;
> + if ( verb ) {
> + /* Set the environment so that programs run in a script also obey --o */
> + putenv("GRASS_OVERWRITE=1");
> + /* No need to check options for existing files if overwrite is true */
> + return(verb) ;
> static int interactive( char *command)
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
