[GRASS-dev] Re: gis.m zooming: 2 new bugs
Michael Barton michael.barton at asu.edu
Wed Sep 20 15:42:23 EDT 2006
Maciej,
This is getting close to finding out what it is you are wanting to see. See
below for additional questions.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Maciej Sieczka <tutey at o2.pl>
> Date: Wed, 20 Sep 2006 20:57:46 +0200
> To: Michael Barton <michael.barton at asu.edu>
> Cc: Michael Barton <c.michael.barton at gmail.com>, grass-dev
> <grass-dev at grass.itc.it>, Moritz Lennert <mlennert at club.worldonline.be>
> Subject: Re: [GRASS-dev] Re: gis.m zooming: 2 new bugs
> That's not what I mean. I mean that the geometry must be preserved
> exactly the way I set it by drawing the zoom box.
So in the example you gave what is it that you think ought to be displayed.
I'm not trying to be a problem, but this is unclear.
You first used a zoom in box to set a region geometry that was tall (N-S)
and narrow (E-W). So far so good.
Then you draw a zoom out box that is smaller in the N-S dimension than the
current region and larger in the E-W dimension than the current region. The
algorithm increases the N-S region extents so that the parts of a map at the
previous north and south edges now fit into the box that you drew on the
screen.
What is it you think should happen with the E-W given the box you've drawn?
> Currently in gis.m,
> using box-zoom-out, this geometry is preserved OK only when I don't
> include a part of an empty map canvas in my zoom box. But if I do that,
> the part of my zoom box that overlaps this empty canvas is not taken
> into account, so the geometry is set wrong (ie. not the way I drew the
> zoom box), thus the resulting region extent is also wrong.
> Is it impossible to fix that?
>> It would help to know if you are actually trying to achieve some kind of
>> meaningful result and what that is, or if you are just trying out tools in
>> various circumstances.
> No, I'm not teasing you for fun.
>> I'm have set the zoom out box tool to treat the case of a zoom out box
>> larger than the current region as undefined, so that it does not change the
>> display region in that dimension (it won't produce an error). This will
>> probably give you the visual effects you are looking for, but I'm not sure.
> IMO the patch should be reverted. It doesn't fix the problem. The issue
> is that geometry is not handled properly if the zoom box overlaps an
> empty map canvas when box-zooming-out, which, as result, leads to a
> bogus region.
It's not a matter of whether the area is empty (i.e., there is no map data
there), it's where the edge of the region is located.
> As such situation (zooming over an empty map canvas) is handled OK in
> the box-zoom-in, I suppose it could also be fixed for box-zoom-out.
> If I still haven't made myself clear in this email, please ask me on.
Even though zooming in and out with a box drawn on the screen appear to be
very much the same, they are not mirror images of each other. The underlying
algorithms to change the region are very different.
Try the change to mapcanvas.tcl and see what you think.
> Maciek
