[GRASS-dev] remove(dir) fails on Windows
Radim Blazek radim.blazek at gmail.com
Fri Sep 22 11:09:51 EDT 2006
Hi.
remove() directory fails on Windows so that vectors cannot be deleted
without error. Patch for lib/vector/Vlib/map.c is attached.
IMPORTANT!
Radim
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20060922/82212774/map.c.obj
