[GRASS-dev] Re: [bug #5161] (grass) v.digit unable to create a new
file
Maciej Sieczka
tutey at o2.pl
Sat Sep 23 06:17:08 EDT 2006
Markus Neteler via RT wrote:
> I have fixed some backslash formatting. Does it help?
No. Still:
ERROR: Cannot open toolbox:
Note: the problem affects v.digit in general, not only when -n (create
a new map) is used. Any v.digit run leads to the error above. I'm
changing the bug title.
> If not, in doc/debugging.txt is a bit of tcl debugging explained. On
> all my systems it works (tcl84). So I cannot reproduce the problem.
Maciek
