[GRASS-dev] GRASS-Python Interface: Vector API added
    Markus Neteler
    neteler at itc.it
    Mon Sep 25 04:10:21 EDT 2006
Thanks, Alessandro.
I have submitted the patches and added
rasteraccess.py and
vectoraccess.py
as examples in CVS. The latter, slightly extended, now reports:
python vectoraccess.py
Vect is 3D:  0
Vect DB links:  1
Map Scale:  1: 24000
Number of lines: 2876
Markus
On Sun, Sep 24, 2006 at 10:43:04PM +0200, Alessandro Frigeri wrote:
> Hello,
> To get the Map_info structure we have to wrap also dig_structs.h (so
> we must add dig_struct.i to the interfaces dir by adding a line in the
> Makefile there).
> I also added some lines to the python-swig interface file to provide
> access to int/float/double arrays.  Find attached  the patch to
> python_grass.i and below the updates to the script proposed by Markus
> that now works with the new Map_info object.
> #!/usr/bin/python
> import python_grass6 as g6lib
> input = 'soils'
> mapset = 'PERMANENT'
> g6lib.G_gisinit('')
> g6lib.Vect_set_open_level (2)
> map = g6lib.Map_info()
> g6lib.Vect_open_old_head (map, input, mapset)
> print 'Vect is 3D: ', g6lib.Vect_is_3d (map)
> g6lib.Vect_open_old(map, input, mapset)
> print 'Vect DB links: ', g6lib.Vect_get_num_dblinks(map)
> g6lib.Vect_close(map)
> ## end of the python script
> Regards,
> Alessandro
> Alessandro Frigeri, PhD
