[GRASS-dev] Vect_get_num_lines() versus Vect_get_num_primitives()
Paul Kelly
paul-grass at stjohnspoint.co.uk
Mon Sep 25 07:13:10 EDT 2006
Hello Moritz
On Mon, 25 Sep 2006, Moritz Lennert wrote:
> When working on a revision of d.vect.chart, I got the feeling that
> Vect_get_num_lines was used as if it returned the number of _all_ the
> features in the map, not only the lines (from lines 49+ of
> display/d.vect.chart/plot.c):
> nlines = Vect_get_num_lines ( Map );
> /* loop through each vector feature */
> for ( line = 1; line <= nlines; line++ ) {
> G_debug ( 3, "line = %d", line );
> ltype = Vect_read_line (Map, Points, Cats, line);
> As you can create charts with vector point, I don't know how this would
> work, if Vect_get_num_lines returns only number of lines.
My understanding is that a point is represented as a line containing only
one node. So the number of lines is equivalent to the number of points. I
have very limited experience with this but in any maps I came across while
testing recent changes to v.surf.idw to remove it's dependency on
topology, this is how points where represented.
Paul
