[GRASS-dev] Re: [GRASS-user] check vector geometry
Michael Barton michael.barton at asu.edu
Mon Sep 25 15:07:27 EDT 2006
Something making things complicated is that
g.region -p
and
g.region -g
return different suites of region values and also format the values
differently for latlon (-g in decimal degrees, while -p uses dd:mm:ss
format). This kind of inconsistency also occurs in other modules (e.g.
r.describe).
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Maciej Sieczka <tutey at o2.pl>
> Date: Mon, 25 Sep 2006 17:09:13 +0200
> To: Glynn Clements <glynn at gclements.plus.com>
> Cc: GRASSLIST <grassuser at grass.itc.it>, Jachym Cepicky
> <jachym.cepicky at centrum.cz>, grass-dev <grass-dev at grass.itc.it>
> Subject: [GRASS-dev] Re: [GRASS-user] check vector geometry
> Given these, how should g.region be fixed then?
> I suppose that -g alone should not work at all. Only when combined with
> -p,-e,-c,-l it should print their machine-readable version. That would
> make things clear and consistent. Of course not a plan for Grass 6.
> Grass 7?
