[GRASS-dev] r.le bugs--list needed
William L. Baker bakerwl at uwyo.edu
Mon Sep 25 16:51:20 EDT 2006
Hello,
I may (still uncertain!) slowly try to get r.le programs to work under
6.X. Here is what I see as problems to be fixed. If anyone knows of
other problems, let me know:
1. r.le.setup fails when a sitefile is requested--update needed
2. r.le.setup does not display properly in the display window
3. with gis.m, r.le.setup does not connect to display window
4. r.le.pixel crashes with a memory problem
5. no r.le.dist program
Bill Baker, Univ. of Wyoming
bakerwl at uwyo.edu
