[Spam/Pourriel] [GRASS-dev] Re: query vector points x,y
Damiano Triglione
damiano.triglione at polimi.it
Wed Sep 27 09:18:12 EDT 2006
You're perfectly right about practical meaning, but I have a theoretical
interest;
another issue is that for a strange reason I may want to use kilometers as
units, so meaningful centimeters are at distant decimal places!
What do you think?
Damiano
----- Original Message -----
To: "'Damiano Triglione '" <damiano.triglione at polimi.it>; "'Maciej Sieczka
'" <tutey at o2.pl>
Cc: <grass-dev at grass.itc.it>
Sent: Wednesday, September 27, 2006 2:50 PM
Subject: RE: [Spam/Pourriel] [GRASS-dev] Re: query vector points x,y
> I'm not sure why, but how much precision do you need? If your projection
> units are in meters, you can't get meaningful precision greater than a
> decimeter anyway. Does it make sense to give coordinates for a position to
> 6
> decimal places if the units are meters? Is your input data that precise?
> Keep in mind that 6 decimal places is giving a precision of 1/10,000th of
> a
> millimeter!
> ~ Eric.
> -----Original Message-----
> From: grass-dev-bounces at grass.itc.it
> To: Maciej Sieczka
> Cc: grass-dev at grass.itc.it
> Sent: 9/27/2006 8:16 AM
> Subject: [Spam/Pourriel] [GRASS-dev] Re: query vector points x,y
> OK, but then I think it is better to use v.out.ascii for this purpose!
> v.out.ascii print coordinates with high precision, while v.to.db -p gives
> only
> a couple of decimals after floating point. Why?
> Damiano
> grass-dev mailing list
> http://grass.itc.it/mailman/listinfo/grass-dev
