[GRASS-dev] Error creating EPSG location using latest cvs
Patton, Eric epatton at nrcan.gc.ca
Wed Sep 27 10:57:32 EDT 2006
Markus,
I'm using Ubuntu 6.06 and gdal 1.3.2.
~ Eric.
-----Original Message-----
To: Patton, Eric
Sent: 9/27/2006 10:53 AM
Subject: Re: [GRASS-dev] Error creating EPSG location using latest cvs
Eric,
please post to the list which OS you are using...
Meanwhile I update and recompile and try again.
Markus
On Wed, Sep 27, 2006 at 11:51:20AM -0300, Patton, Eric wrote:
> I just updated my cvs, and reinstalled, and the problem persists. In
fact, I
> get the same error for _any_ EPSG code used.
> ~ Eric.
> From: grass-dev-bounces at grass.itc.it
> To: 'grass-dev at grass.itc.it'
> Sent: 9/27/2006 10:23 AM
> On Wed, Sep 27, 2006 at 10:01:51AM -0300, Patton, Eric wrote:
> > I encountered an error creating a new Location from the grass63 gui
> using
> > EPSG code #4326 (Geographic WGS84). I checked the path of my epsg
> file, and
> > it's fine. Even grepping code 4326 within the epsg file is OK:
> > child process exited abnormally
> >     while executing
> > "exec -- $env(GISBASE)/etc/grass-xterm-wrapper -e
> > $env(GISBASE)/etc/make_location_epsg.sh  $epsg_code $epsgLocation
> $locpath
> > >@stdout 2>@stderr"
> >     invoked from within
> > ".optPopup.submit invoke"
> >     ("uplevel" body line 1)
> >     invoked from within
> > "uplevel #0 [list $w invoke]"
> >     (procedure "tk::ButtonUp" line 22)
> >     invoked from within
> > "tk::ButtonUp .optPopup.submit"
> >     (command bound to event)
> > Has there been any updates made to proj/gdal lately that may have
> affected
> > this?
> Eric,
> I just tried, it works (yesterday (my time) gis.m etc were broken).
> Please update from CVS again, hopefully it works again.
> The recent update to EPSG 6.11 shouldn't harm at all.
> Markus
> grass-dev mailing list
> http://grass.itc.it/mailman/listinfo/grass-dev
Markus Neteler  <neteler itc it>  http://mpa.itc.it/markus/
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
