[Spam/Pourriel] [GRASS-dev] Re: query vector points x,y
Wed Sep 27 11:56:21 EDT 2006
Patton, Eric wrote:
> True enough. I'm not sure why v.to.db only prints a few decimal
> places. I'm assuming there must be some print statement within one of
> the c programs of v.to.db that determines this.
probably lib/db/dbmi_base/valuefmt.c
For GRASS 6.1 I changed db_convert_value_to_string() there to do:
        case DB_C_TYPE_DOUBLE:
            sprintf (buf, "%lf",db_get_value_double(value));
            G_trim_decimal(buf);
            break;
which helps.
Damiano: are you using 6.1+? 6.0 will trim decimals as "%f" or so.
Maybe there are more places that need the above fix.
%lf prints with double precision and G_trim_decimal() removes trailing
zeros.
Hamish
