[GRASS-dev] RE: [GRASS-user] Error importing DMS into standar
dformat usingv. in.ascii
Glynn Clements
glynn at gclements.plus.com
Wed Sep 27 17:31:05 EDT 2006
Patton, Eric wrote:
> Ok, I finally got my points imported with this command:
> echo "B 5 1
> 66.5 44.0
> 66.5 44.25
> 66.0 44.25
> 66.0 44.0
> 66.5 44.0
> 1 1" | v.in.ascii -n output=new_test format=standard
FWIW, feeding sizeable amounts of literal text to a command's stdin is
best done using a "here document" rather than using "echo", e.g.:
v.in.ascii -n output=new_test format=standard <<EOF
B 5 1
66.5 44.0
66.5 44.25
66.0 44.25
66.0 44.0
66.5 44.0
1 1
EOF
> Note that the field separator is a space, but v.in.ascii is not explicitly
> told so using the fs= parameter, which is kind of odd.
The fs= option only applies to format=point. Actually, most of the
options only apply to format=point.
v.in.ascii is essentially two different programs in one; format=point
and format=standard have very little in common.
