[GRASS-dev] adding 'desc' to dbf sql driver
Daniel Calvelo
dca.gis at gmail.com
Wed Sep 27 21:32:37 EDT 2006
Hi Moritz. See below
On 9/22/06, Moritz Lennert <mlennert at club.worldonline.be> wrote:
> Hi,
> Reworking on d.vect.chart I need to be able to sort the reults of a
> select in descending order. As the dbf driver doesn't allow this, I have
> been trying to see how to extend the driver.
> IIUC, it's "just" a question of conditionalising the qsort call on line
> 566 of db/drivers/dbf/dbfexe.c, and (would this be enough ?) use
> qsort(set, nset, sizeof(int), -cmp_row);
That might work. Although it would be much nicer to use an expression
as sorting order.
> if the desc keyword is present.
> However, I have some trouble understanding the parsing of the sql
> statement.
> If I understand correctly, we would need to extent the SQLPSTMT
> structure in include/sqlp.h to include a flag for 'desc' (and possible
> 'asc') and the parser to identify and set that flag.
> But this is as far as I get. Could someone help me with this ?
Quick shot: you need to
- change SQLPSTMT to have an "order"/"direction"/"sort_order" element
- add ASC and DESC in lex.l as tokens
- change yac.y to stg like:
y_order: y_order_asc | y_order_desc ;
y_order_asc:
NAME ASC { sqpOrderColumn( $1 ); sqpOrderDirection( 1 ); }
y_order_desc:
NAME DESC { sqpOrderColumn( $1 );sqpOrderDirection( 2 );}
- add in sql.c a sqpOrderDirection() function that sets the element
you added to SQLPSTMT
(Alternatively, you can change sqpOrderColumn() to receive two
arguments, one being the sorting direction. I'd also rather #define
SORT_ASC and SORT_DESC instead of using magic numbers as above.)
- use that value in dbfexe.c to test the sorting direction.
HTH,
Daniel.
> Thanks,
> Moritz
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
-- Daniel Calvelo Aros
