[GRASS-dev] Re: bug in Vect_cidx_find_next() ?
Radim Blazek
radim.blazek at gmail.com
Fri Sep 29 05:17:39 EDT 2006
On 9/29/06, Moritz Lennert <mlennert at club.worldonline.be> wrote:
> Radim Blazek wrote:
> > Yes,
> > it seems to be bug, I think that on row 296 in cindex.c
> > the requested cat should also be checked, not only the type.
> > But I am tired now, please check it twice.
> Changing that line into
> if ( ci->cat[cat_index][0] == cat && ci->cat[cat_index][1] & type_mask )
> works. Thanks !
> But I don't really understand how this could happen, as I thought the
> following lines (286-288) should take care of this before:
> while ( cat_index > start_index ) {
> if ( ci->cat[cat_index-1][0] != cat ) {
> break;
No, this goes down to lowes index of this cat because bsearch
does not return the first item.
To simplify use of cat index in modules I would suggest 2 new functions
(not tested/compiled):
void Vect_cidx_find_lines ( struct Map_info *Map, int layer, int cat,
struct ilist *lines )
int type, line;
struct Cat_index *ci;
Vect_reset_list ( lines );
int field_index = Vect_cidx_get_field_index ( Map, layer );
ci = &(Map->plus.cidx[field_index]);
int idx = Vect_cidx_find_next ( Map, field_index, cat, 0,
GV_LINES|GV_POINTS, &type, &line );
if ( idx == -1 ) return;
do {
if ( !(ci->cat[idx][1] & GV_LINES|GV_POINTS)
|| ci->cat[idx][0] != cat )
break;
Vect_list_append ( lines, ci->cat[idx][2] );
idx++;
} while ( idx < ci->n_cats );
return;
and similarly Vect_cidx_find_areas, then in module:
struct ilist *lines = Vect_new_list();
Vect_cidx_find_lines ( Map, layer, cat, lines );
for ( i = 0; i < lines->n_values; i++ )
line = lines->value[i];
Vect_read_line ( Map, Points, NULL, line );
Radim
> So it might actually be a problem in the determination of cat_index
> which is higher than it should be.
> But just as you, I'm too tired now to look any deeper into this...
> Moritz
> > Bravo Moritz!
> > Radim
> > On 9/28/06, Moritz Lennert <mlennert at club.worldonline.be> wrote:
> >> Hello,
> >> Trying to rework d.vect.chart I am using the Vect_cidx_find_next()
> >> function.
> >> However, using a map with areas I get behaviour which seems incorrect
> >> and which I cannot explain.
> >> I have the following category index (result of Vect_cidx_dump(Map,
> >> stdout)):
> >> [Field 0]
> >> Field 1 number of unique cats: 589 number of cats: 1185
> >> number of types: 3
> >> type | count
> >> 8 | 592
> >> 4 | 1
> >> 64 | 592
> >> category | type | line/area
> >> 11001 | 8 | 1895
> >> 11001 | 64 | 127
> >> 11002 | 8 | 1810
> >> 11002 | 64 | 42
> >> 11004 | 8 | 1874
> >> 11004 | 64 | 106
> >> 11005 | 8 | 1923
> >> 11005 | 64 | 155
> >> 11007 | 8 | 1866
> >> etc.
> >> Now, when I launch
> >> Vect_cidx_find_next( Map, field_index=1, cat=11002, type=15,
> >> start_index=3, &stype, &sid )
> >> it returns 4 and line id=1874.
> >> This is wrong as the fourth item in the index, which does have line id
> >> 1874, has cat 11004 and not cat 11002. This is confirmed by launching
> >> Vect_cidx_get_cat_by_index ( Map, field_index, 4, &testcat, &testtype,
> >> &testid)
> >> which returns testcat = 11004.
> >> Am I right in assuming that there is a bug in Vect_cidx_find_next, or am
> >> I misunderstanding something here ?
> >> I don't have this problem with a pure point file, which only has one
> >> type:
> >> Field 1 number of unique cats: 589 number of cats: 593
> >> number of types: 1
> >> type | count
> >> 1 | 593
> >> 11001 | 1 | 97
> >> 11002 | 1 | 12
> >> 11002 | 1 | 593
> >> 11004 | 1 | 76
> >> 11005 | 1 | 125
> >> 11007 | 1 | 68
> >> So this seems to be linked to the type handling.
> >> Any ideas,
> >> Moritz
> > grass-dev mailing list
> > grass-dev at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grass-dev
