[GRASS-dev] r.le--after some fixes still needs work
Paolo Cavallini
cavallini at faunalia.it
Sat Sep 30 02:29:35 EDT 2006
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
that's one of the reasons that promptet our investment in r.li. I
seriusly think your expertise and time will produce faster and better
output if you concentrate on r.li. Please note that r.li is fully
functional (it just does not have many modules implemented, but due to
its modularity this should be easy and fast to do).
Or there is a point I'm missing?
All the best.
pc
Brad Douglas ha scritto:
> I got everything working last night, but there is one large issue: I
> believe the modules needs segmentation. The largest region I have been
> able to work with is about 150x150 with MAX defined as 100000. There is
> no checking against MAX, so if you run out of allocated memory, it will
> segv().
Paolo Cavallini
email+jabber: cavallini at faunalia.it
www.faunalia.it
Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy Tel: (+39)348-3801953
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.5 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFFHg7P/NedwLUzIr4RAk98AJ4kPHVP0AzP3TOLgiIlOKy49uAUNwCfVU2E
cR9ICPz3s6EwLl+idUfgiiE=
=4mDL
-----END PGP SIGNATURE-----
