[GRASS-dev] compile error?
Mon Apr 2 22:30:37 EDT 2007
Paolo Cavallini wrote:
> Thanks. However, it still fails:
> Installing with make install...
> ========================= Installation results ======================
> echo /home/paolo/Desktop/buildpackage/grass6/bin.i686-pc-linux-gnu/grass63
> make[1]: Entering directory `/home/paolo/Desktop/buildpackage/grass6'
> test -d /usr/local/grass-6.3.cvs || mkdir -p -m 755 /usr/local/grass-6.3.cvs
> test -d /usr/local/bin || mkdir -p -m 755 /usr/local/bin
> sed -e "s#^GISBASE.*#GISBASE=/usr/local/grass-6.3.cvs#"
> /home/paolo/Desktop/buildpackage/grass6/bin.i686-pc-linux-gnu/grass63 >
> /usr/local/bin/grass63
> chmod a+x /usr/local/bin/grass63
> sed -e "s#^WINGISBASE.*#WINGISBASE=/usr/local/grass-6.3.cvs#" /home/paolo/Desktop/buildpackage/grass6/bin.i686-pc-linux-gnu/grass63.bat > /usr/local/bin/grass63.bat
> chmod a+x /usr/local/bin/grass63.bat
> cd /home/paolo/Desktop/buildpackage/grass6/dist.i686-pc-linux-gnu ; tar cBf - bin | (cd /usr/local/grass-6.3.cvs ; tar xBf - ) 2>/dev/null
> make[1]: [real-install] Error 2 (ignored)
> cd /home/paolo/Desktop/buildpackage/grass6/dist.i686-pc-linux-gnu ; tar cBf - bwidget | (cd /usr/local/grass-6.3.cvs ; tar xBf - ) 2>/dev/null
> cd /home/paolo/Desktop/buildpackage/grass6/dist.i686-pc-linux-gnu ; tar cBf - docs | (cd /usr/local/grass-6.3.cvs ; tar xBf - ) 2>/dev/null
> cd /home/paolo/Desktop/buildpackage/grass6/dist.i686-pc-linux-gnu ; tar cBf - driver | (cd /usr/local/grass-6.3.cvs ; tar xBf - ) 2>/dev/null
> cd /home/paolo/Desktop/buildpackage/grass6/dist.i686-pc-linux-gnu ; tar cBf - etc | (cd /usr/local/grass-6.3.cvs ; tar xBf - ) 2>/dev/null
> cd /home/paolo/Desktop/buildpackage/grass6/dist.i686-pc-linux-gnu ; tar cBf - fonts | (cd /usr/local/grass-6.3.cvs ; tar xBf - ) 2>/dev/null
> cd /home/paolo/Desktop/buildpackage/grass6/dist.i686-pc-linux-gnu ; tar cBf - man | (cd /usr/local/grass-6.3.cvs ; tar xBf - ) 2>/dev/null
> cd /home/paolo/Desktop/buildpackage/grass6/dist.i686-pc-linux-gnu ; tar cBf - scripts | (cd /usr/local/grass-6.3.cvs ; tar xBf - ) 2>/dev/null
> if [ 1 -eq 1 ] ; then cd /home/paolo/Desktop/buildpackage/grass6/dist.i686-pc-linux-gnu ; tar cBf - - locale | (cd /usr/local/grass-6.3.cvs ; tar xBf - ) 2>/dev/null ; fi
Can you try running the failing commands manually without the
"2>/dev/null", e.g.
