[GRASS-dev] Re: discussion: replacing ps.map
Markus Neteler neteler at itc.it
Wed Apr 4 03:56:39 EDT 2007
Hamish wrote on 04/04/2007 04:22 AM:
> Glynn Clements wrote:
>> I mean that the application has to draw styled lines using a sequence
>> of primitives. E.g. if you want a double line (#1000 on p39), you have
>> to draw two lines, with the correct offsets.
> v.parallel or v.buffer
Note that v.parallel is partially broken as it produces unconnected lines if
you generate a parallel line to a polyline.
Markus
ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
ITC -> since 1 March 2007 Fondazione Bruno Kessler
