[GRASS-dev] [grass-code I][355] A lot of <defunct> processes
around while working
Glynn Clements
glynn at gclements.plus.com
Wed Apr 4 15:06:54 EDT 2007
Michael Barton wrote:
> >> frankie 5484 1 2 16:49 pts/11 00:00:32 wish
> >> /usr/lib/grass/etc/gm/gm.tcl -name gm_tcl
> >> frankie 5525 5484 0 16:49 pts/11 00:00:00 [g.region] <defunct>
> >> frankie 5527 5484 0 16:50 pts/11 00:00:00 [g.region] <defunct>
> >> frankie 5529 5484 0 16:50 pts/11 00:00:00 [g.region] <defunct>
> > [snip]
> > AFAICT, this is due to MapCanvas::set_wind; it should be using "exec"
> > rather than "open |...".
> This is because of the need to run g.region -gp and read the results back,
> in order to get current region information.
Nope. The code in question is:
proc MapCanvas::set_wind {mon args overwrite} {
variable zoom_attrs
global devnull
set values [MapCanvas::currentzoom $mon]
set options {}
foreach attr $zoom_attrs value $values {
if {$attr != "rows" && $attr != "cols"} {
lappend options "$attr=$value"
if {$overwrite == 1} {
open [concat "|g.region --o" $options $args "2> $devnull"]
} else {
open [concat "|g.region" $options $args "2> $devnull"]
Nothing is using the returned descriptor. More importantly, nothing is
closing it, so the process will remain a zombie forever.
This should be using exec, not open.
