[GRASS-dev] [grass-code I][361] v.edit segfaults
grass-codei at wald.intevation.org
Fri Apr 6 10:37:29 EDT 2007
code I item #361, was opened at 2007-04-06 16:37
Status: Open
Priority: 3
Submitted By: Jachym Cepicky (jachym)
Assigned to: Martin Landa (martinl)
Summary: v.edit segfaults
Issue type: module bug
Issue status: None
GRASS version: CVS HEAD
GRASS component: vector
Operating system: Linux
Operating system version: RH8
GRASS CVS checkout date, if applies (YYMMDD): 6.4.
Initial Comment:
v.edit tool=catadd coords=223.26666667,493.28958333 map=train cats=0
Segmentation fault
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=361&group_id=21
