[GRASS-dev] No longer able to open a mapset by symbolic link
Glynn Clements
glynn at gclements.plus.com
Fri Apr 6 11:08:31 EDT 2007
Glynn Clements wrote:
> > >> I just retrieved the latest weekly CVS snapshot for GRASS and found
> > >> I'm no longer able to access mapsets that are referred to by symbolic
> > >> links in linux.
> > >> Is this intended behaviour (possibly related to the windows port)? Or a bug?
> > > AFAIK, having symlinks to mapset directories has never been
> > > intentionally supported; it just happened to work.
> > I am long term user of such mapset links, it would be a major problem for us
> > to no longer have this possibility. Just to express interest in this
> > issue...
> In that case, we need to add a G_stat(), and change some uses of
> G_lstat() to G_stat().
> Current users of G_lstat() are:
> general/manage/lib/do_copy.c
> recursive_copy(), used by do_copy(), used by g.copy
> lib/gis/mapset_msc.c
> G__mapset_permissions(), G__mapset_permissions2()
> lib/gis/remove.c
> recursive_remove(), used by G_remove()
> lib/gis/unix_socks.c
> _get_make_sock_path(), used by G_sock_get_fname()
> lib/gis/user_config.c
> _make_toplevel(), _make_sublevels(), both used by G_rc_path()
> AFAICT, the problems are due to G__mapset_permissions() and/or
> G__mapset_permissions2(). These can probably be safely changed to use
> stat() instead.
FWIW, I've changed these two to use G_stat(), so symlinks to mapsets
should work now.
