[GRASS-dev] discussion: replacing ps.map
Dylan Beaudette
dylan.beaudette at gmail.com
Fri Apr 6 13:02:59 EDT 2007
On Friday 06 April 2007 09:26, Glynn Clements wrote:
> If you're getting monochrome output, use:
> export GRASS_TRUECOLOR=TRUE
> to get colour PostScript.
> I made monochrome the default because that results in the most
> portable code (a minimal level 1 PostScript implementation doesn't
> support colour).
Great! I just tried this with excellent results. Perhaps the longer rendering
time for the PS driver is that it is rendering the raster data at the highest
possible resolution. The output from a simple d.rast + d.vect is comparable
to the quality of GMT-produced output.
Cheers,
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
