[GRASS-dev] Re: [GRASS-user] Views in pgSQL
Moritz Lennert mlennert at club.worldonline.be
Thu Apr 12 10:59:42 EDT 2007
On 11/04/07 18:15, Moritz Lennert wrote:
> On 11/04/07 17:37, Markus Neteler wrote:
>> On Wed, Apr 11, 2007 at 05:25:24PM +0200, Moritz Lennert wrote:
>>> On 11/04/07 13:48, Jaros??aw Jasiewicz wrote:
>>>> BTW:
>>>> Pg Views are very important for me when I connect-reconnect vector
>>>> files to different atribute table. I use (used!) views insted of
>>>> original table to avoid occasional removing original data and to
>>>> speed up transfer limiting data in views only to these needed for
>>>> (sorry, I think everybody knows it)
>>> I completely agree with you. Being able to connect maps to views is
>>> fundamental in my eyes.
>> Yes. But we need a reasonable implementation.
>> Anyone with suggestions how to implement it?
> For me the choice is either
> 1) to consider views as tables (and thus change the way the individual
> drivers list tables) or
> 2) to treat them as separate and change v.db.connect so that it checks
> for both.
> 1) seems much easier to implement, 2) seems cleaner in case we need to
> list tables only, not views, in other contexts than v.db.connect.
As I don't see any reason why 1) should be a problem in the context of
GRASS, I've had done a quick implementation of this for the pg driver
(diff attached). For me it seems to work.
Anyone opposed to committing this ?
For sqlite and mysql, I will have to do some more reading to learn how
to get the relevant info (i.e. list of user-relevant views). If someone
has some knowledge about this, I would be grateful.
Moritz
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20070412/cb72a179/listtab.bin
