[GRASS-dev] problem with r.colors on Mac
Michael Barton michael.barton at asu.edu
Thu Apr 12 20:43:22 EDT 2007
Here is a screenshot of Cesium Magnetometry of a Spanish Neolithic site
(early farming ca. 4200 BC). I used Glynn's new histogram equalized gyr
color table for the magnetometry values and show them in NVIZ.
Michael
<http://www.public.asu.edu/~cmbarton/files/grass_screenshots/punxo_1_coloren
hanced.jpg>
On 4/12/07 2:53 PM, "Glynn Clements" <glynn at gclements.plus.com> wrote:
> Glynn Clements wrote:
>> Beyond that, I'd like to propose eliminating most of the individual
>> G_make_*_colors() functions in favour of a general purpose function
>> which takes the name of a rules file as an argument.
> I've done this, and would appreciate it if the changes could receive
> some testing.
> The core of r.colors' color=rules and rules= options is now in
> lib/gis/color_rules.c. Apart from the lower-level functions used by
> r.colors, this provides two new functions:
> int G_make_colors(struct Colors *colors, const char *name, CELL min, CELL
> max);
> int G_make_fp_colors(struct Colors *colors, const char *name, DCELL min, DCELL
> max);
> These effectively supersede most of the G_make_*_[fp_]colors()
> functions, i.e.:
>  G_make_aspect_colors
>  G_make_byg_colors
>  G_make_byr_colors
>  G_make_grey_scale_colors
>  G_make_gyr_colors
>  G_make_rainbow_colors
>  G_make_ramp_colors
>  G_make_ryg_colors
>  G_make_wave_colors
> plus the _fp_ versions.
> A call such as:
> G_make_rainbow_colors(&colors, min, max);
> can be replaced with:
> G_make_colors(&colors, "rainbow", min, max);
> The following functions don't have direct equivalents:
>  G_make_histogram_eq_colors
>  G_make_histogram_log_colors
>  G_make_random_colors
> The first two can be replaced with a combination of
> G_make_colors(&colors, "grey", ...) and either G_histogram_eq_colors()
> or G_log_colors(), e.g.:
> G_make_colors(&colors, "grey", min, max);
> G_histogram_eq_colors(&colors_tmp, &colors, &statf);
> colors = colors_tmp;
> or:
> G_log_colors(&colors_tmp, &colors, 100);
> [I will modify G_{histogram_eq,log}_colors to allow the colour table
> to be updated in-place, to avoid the need for a temporary variable.]
> G_make_random_colors() cannot be implemented by means of colour rules,
> and so will remain.
> The corresponding changes to r.colors are:
> 1. "r.colors color=rules" is implemented using the lower level functions
> G_read_color_rules(), G_parse_color_rule() etc, with r.colors itself
> handling terminal interaction.
> 2. "r.colors rules=" just calls G_make_fp_colors() with the specified
> rule name.
> Also, the rules files have been moved to the lib/gis/color directory.
> The next step is to replace the various G_make_*_[fp_]colors()
> functions with wrappers around G_make_[fp_]colors(). Unless that shows
> up any problems, I'll replace the use of G_make_*_[fp_]colors() with
> direct calls to G_make_[fp_]colors(), and merge the rules= and color=
> options in r.colors.
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
