[GRASS-dev] ascii export and import, large file problem
Helena Mitasova
hmitaso at unity.ncsu.edu
Thu Apr 12 21:02:37 EDT 2007
Jerry,
r.slope.aspect should work with lat-long, it calls G_distance that says
This routine computes the distance, in meters, from
* <b>x1</b>,<b>y1</b> to <b>x2</b>,<b>y2</b>. If the projection is
* latitude-longitude, this distance is measured along the geodesic. Two
* routines perform geodesic distance calculations.
It should also support the wrap-around.
Maybe this should be added to the man page.
Helena
Helena Mitasova
Dept. of Marine, Earth and Atm. Sciences
1125 Jordan Hall, NCSU Box 8208,
Raleigh NC 27695
http://skagit.meas.ncsu.edu/~helena/
On Apr 12, 2007, at 8:10 PM, Gerald Nelson wrote:
> This is related to my earlier question (to which noone responded)
> about why the slope calculation can't take lat-long data and just
> figure out the slope from the z values.
> The srtm elevation data comes in lat-long values in cells that are
> square. In order to get slope, which we need for a cost map, we
> project to a utm value in the center of the region we need
> (UTM37N). Grass does this projection and generates rectangular
> pixels. Then we do the slope calculation and other things to
> generate a cost surface.
> We need the ascii output to read the cost data into our custom
> neural net program (because we don't have any C programmers, just a
> java programmer).
> So its possible that what we observed when we did the export/import
> process is a function of the square/rectangular pixel issue
> interacting with the arc export/import that assumes pixels are square.
> My ideal would be to not have to take the data out of lat-long, but
> I have to do that to use the slope calculations.
> Hope this all makes some sense.
> Regards, Jerry
> ---- Original message ----
>> Date: Thu, 12 Apr 2007 23:58:16 +0100
>> From: Glynn Clements <glynn at gclements.plus.com>
>> Subject: RE: [GRASS-dev] ascii export and import, large file problem
>> To: "Jerry Nelson" <gnelson at uiuc.edu>
>> Cc: "'grass-dev'" <grass-dev at grass.itc.it>
>> Jerry Nelson wrote:
>>>>> I'm using grass6.3 updated today so the large file support for
>>>>> the ascii
>>>>> commands is included. I export a file using r.out.arc and then
>>>>> read it back
>>>>> in using r.in.arc. The attached jpg shows the original raster
>>>>> on the right.
>>>>> The screen on the left is the original raster minus the
>>>>> exported and
>>>>> imported version. The bottom two thirds or so of the left
>>>>> raster is zero, as
>>>>> it should be, but the top 1/3 has a bunch of small values
>>>>> (range is - to
>>>>> +2.9).
>>>> My first guess is that the export->import process is changing the
>>>> vertical extent of the map slightly, so the calculation in the
>>>> upper
>>>> portion of the map is using cells which are off by one row.
>>>> What does r.info say about the bounds of the two maps?
>>> To provide more info,
>>> The 'after' info
>>> Rows: 21048
>>> Res: 119.047796
>>> The 'before' info
>>> Rows: 21048
>>> Res: 119.05225396
>> 119.05225396 - 119.047796 = 0.00445796
>> 0.00445796 * 21048 = 93.8311421
>> So, the imported map has shrunk by almost a whole cell. That would
>> certainly explain the results.
>> Ah, I see where the problem lies:
>>> The 'before' info
>>> Res: 119.05225396
>>> Res: 119.04779557
>> Your cells aren't square, but the ArcGrid format doesn't appear to
>> allow for non-square cells (single "cellsize" value rather than
>> separate x/y values). r.out.arc uses the horizontal resolution for
>> the
>> cellsize value; if the vertical resolution is different, you lose.
>> This specific issue can't be fixed. However, if the original data had
>> square cells, something is going wrong on the initial import.
>> We might want to add a check for this to r.out.arc. We can't actually
>> do anything beyond warn you that exporting will lose information,
>> although that's better than nothing.
> Gerald Nelson
> Professor, Dept. of Agricultural and Consumer Economics
> University of Illinois, Urbana-Champaign
> office: 217-333-6465
> cell: 217-390-7888
> 315 Mumford Hall
> 1301 W. Gregory
> Urbana, IL 61801
> grass-dev mailing list
> http://grass.itc.it/mailman/listinfo/grass-dev
