[GRASS-dev] [grass-code I][370] Missing proto.h header file in
v.edit
grass-codei at wald.intevation.org
Mon Apr 16 04:47:06 EDT 2007
code I item #370, was opened at 2007-04-16 10:47
Status: Open
Priority: 4
Submitted By: Sören Gebbert (huhabla)
Assigned to: Martin Landa (martinl)
Summary: Missing proto.h header file in v.edit
Issue type: module bug
Issue status: None
GRASS version: CVS HEAD
GRASS component: vector
Operating system: all
Operating system version: Debian Linux testing (etch)
GRASS CVS checkout date, if applies (YYMMDD): 070416
Initial Comment:
Compilation of v.edit is broken.
The header file "proto.h" is missing.
Soeren
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=370&group_id=21
