[GRASS-dev] Unused files
Markus Neteler
neteler at itc.it
Mon Apr 16 17:19:53 EDT 2007
On Mon, Apr 16, 2007 at 06:03:12PM +0100, Glynn Clements wrote:
> There are currently 78 source files whose functions don't appear to be
> used by anything.
> Some of these may be used by components which aren't being compiled on
> my system, and some have been added with the intention of future use.
> OTOH, some of them may simply be obsolete.
> Please provide comments as to whether specific files should or
> shouldn't be removed.
> The complete list is:
> lib/cdhc/enormp.c | enormp
> lib/cdhc/shapiro2.c | shapiro_francia
> lib/cdhc/shapiroe.c | shapiro_wilk_exp
> lib/cdhc/cvmw2e.c | cramer_von_mises_exp
> lib/cdhc/kse.c | kolmogorov_smirnov_exp
> lib/cdhc/kuiprsve.c | kuipers_v_exp
> lib/cdhc/watsonue.c | watson_u2_exp
> lib/cdhc/andrsnde.c | anderson_darling_exp
> lib/cdhc/chisqe.c | chi_square_exp
Probably these cdhc/ should go into gmath/ in any case for
future developments?
[ ... dbmi ...]
I feel that DBMI was left in the middle of its development,
in particular Radim was digging through and making it
functional (the needed parts). I have no idea which parts
can be savely abandoned.
> lib/gmath/la.c | G__matrix_add
The la stuff us the LAPACK wrapper and needed for i.spec.unix
(Spectral Unmixing) on which Brad is working to make it
ready for GRASS 6 (it's one of my MSc modules). Please keep.
> lib/gmath/svd.c | G_svbksb
> lib/gmath/svd.c | G_svdcmp
> lib/gmath/svd.c | G_svelim
Single Value Decomposition was originally in lib/gis/, I had
moved it there and originally used it for Spectral Unmixing
(matrix inversion). In the end I had to use a different
approach. But probably SVD is useful for someone in future.
> lib/imagery/add_cov.c | I_add_covariances
> lib/imagery/advance.c | I_tape_advance
> lib/imagery/ask.c | I_ask
> lib/imagery/ask_subgrp.c | I_ask_subgroup_new
> lib/imagery/ask_subgrp.c | I_ask_subgroup_old
> lib/imagery/band_io.c | I_close_band
> lib/imagery/band_io.c | I_open_band_new
> lib/imagery/colors.c | I_free_group_colors
> lib/imagery/colors.c | I_read_group_blu_colors
> lib/imagery/colors.c | I_read_group_colors
> lib/imagery/colors.c | I_read_group_grn_colors
> lib/imagery/colors.c | I_read_group_red_colors
> lib/imagery/colors.c | I_write_group_blu_colors
> lib/imagery/colors.c | I_write_group_colors
> lib/imagery/colors.c | I_write_group_grn_colors
> lib/imagery/colors.c | I_write_group_red_colors
> lib/imagery/image.c | I_close_image
> lib/imagery/image.c | I_get_image_row
> lib/imagery/image.c | I_image_colors
> lib/imagery/image.c | I_open_image
> lib/imagery/image.c | I_translate_image_data
> lib/imagery/open.c | I_open_group_file_new
> lib/imagery/open.c | I_open_group_file_old
> lib/imagery/percent.c | I_percent
> lib/imagery/proj.c | I_must_be_imagery_projection
> lib/imagery/sig2cats.c | I_signature_to_cats
These imagery functions, if really unused, are probably
delete candidates.
> lib/vector/Vlib/dbcolumns.c | Vect_get_column_names
> lib/vector/Vlib/dbcolumns.c | Vect_get_column_names_types
> lib/vector/Vlib/dbcolumns.c | Vect_get_column_types
> lib/vector/Vlib/graph.c | Vect_graph_add_edge
> lib/vector/Vlib/graph.c | Vect_graph_build
> lib/vector/Vlib/graph.c | Vect_graph_init
> lib/vector/Vlib/graph.c | Vect_graph_set_node_costs
> lib/vector/Vlib/graph.c | Vect_graph_shortest_path
> lib/vector/Vlib/overlap.c | V__map_overlap
> lib/vector/Vlib/overlay.c | Vect_overlay
> lib/vector/Vlib/overlay.c | Vect_overlay_and
> lib/vector/Vlib/overlay.c | Vect_overlay_str_to_operator
I am suprised to see these Vect functions unused. Really sure?
> lib/vector/dglib/avl.c | avl_allocator_default
avl: libavl - library for manipulation of binary trees
I think we have also lib/btree/ is that's the same purpose?
No idea about the other functions.
Markus
