[GRASS-dev] problem with r.colors on Mac
Michael Barton
michael.barton at asu.edu
Tue Apr 17 00:31:39 EDT 2007
On 4/11/07 3:42 AM, "Glynn Clements" <glynn at gclements.plus.com> wrote:
>> If read is a problem, what is an alternative?
> gets.
> Gronsole::output_to_gronsole is written on the assumption that it will
> get complete lines. Gronsole::readout tries to do this, but fails to
> allow for the fact that "read" may return arbitrary chunks of data
> (i.e. partial lines).
> If the stream is in non-blocking mode, gets will return an empty
> string if a complete line isn't available. The fblocked function can
> be used to distinguish this from the case where the process wrote a
> blank line. Also, after this case occurs, another readable event won't
> be generated for the stream until a complete line is available.
>> I don't understand the
>> gronsole code very well (didn't write it), but I might be able to fix a
>> specific issue like this.
> Gronsole::readout is the relevant function.
Glynn,
Now that I have cvs access again and could update, I tried to fix this. I
changed Gronsole::readout as indicated below. Gronsole seems to work OK with
the change, but the TckTk GUI still crashes when I run r.colors e. It also
seems to crash more often with other commands too. I¹m guessing its the same
cause. The change below does not seem to fix it, but I want to know if this
is what you had in mind.
##### ORIGINAL CODE #####
proc Gronsole::readout {path ci mark fh} {
set str [read $fh]
if {[string length $str] != 0} {
Gronsole::add_data_tag $path $ci out
set lines [split $str "\n"]
foreach line [lrange $lines 0 [expr [llength $lines] - 2]] {
Gronsole::output_to_gronsole $path $mark $ci [list cmd$ci
cmd$ci-out] "$line\n"
set last [lindex $lines end]
if {$last != {}} {
cmd$ci-out] $last
$path.text see $mark
##### REVISED CODE #####
# I left this first part in because it seems to simply make an output locale
if there is something in $fh
set str [read $fh]
# here I changed all the above code to use gets and read line by line rather
than create line by line output with split
while {[gets $fh line] >= 0} {
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20070416/e389272f/attachment.html
