[GRASS-dev] etc file finder, take 2
William Kyngesburye
woklist at kyngchaos.com
Wed Apr 18 09:57:50 EDT 2007
(ooh, my brain hurts after this - not made for C)
Here's what I came up with. It uses an env var, GRASS_ADDON_ETC,
much like the PATH and GRASS_ADDON_PATH vars - a colon-delimited list
of paths to look in. And finally checks the GRASS application etc/.
It returns the full path to the found file or folder, or null if not
found.
Skipped content of type multipart/appledouble-------------- next part --------------
And a companion g.findetc for use in scripts:
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20070418/d03e15d5/main.obj
Comments welcome. As before, I'm not much of a C programmer, so
there is probably something wrong - maybe memory cleanup needed or
very inefficient. At least it tested OK.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"This is a question about the past, is it? ... How can I tell that
the past isn't a fiction designed to account for the discrepancy
between my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
