[GRASS-dev] etc file finder, take 2
William Kyngesburye
woklist at kyngchaos.com
Wed Apr 18 12:46:42 EDT 2007
Thanks...
On Apr 18, 2007, at 11:16 AM, Glynn Clements wrote:
> The main one is that I'd suggest using G_tokenize() to do most of the
> work for you.
(more C details that escape me...)
My little (basic) C book says a program shouldn't alter an env var
returned by getenv, and G_tokenize() says it changes the token to
null to terminate token strings (which is what I originally did
myself before I read that bit about getenv). Is that what that char
** or const char * takes care of somehow, do either make a copy of
the env var? Or is it part of the tokenize initialization?
> Also, make the argument "const char *" (you don't need
> to modify it) and use GPATH_MAX as the size of the path buffer (I've
> been replacing various random constants with that value as I find
> them; also for GNAME_MAX and GMAPSET_MAX)..
Ah, I used an older find_file as a starting point. I see you updated
this yesterday.
> E.g. (untested):
> static char *G__find_etc(const char *name)
> const char *pathlist = getenv("GRASS_ADDON_ETC");
> char path[GPATH_MAX];
I'll give this a closer look and try it this evening.
> Also:
>> #include <grass/etc.h>
> Not needed; add it to gisdefs.h.
Oops, leftover from the earlier configured-paths version. Not needed
now. But, I do have the prototype for G_find_etc() in gisdefs.h.
>> And a companion g.findetc for use in scripts:
>> exit(fpath==NULL);
> exit(fpath ? EXIT_SUCCESS : EXIT_FAILURE);
got it.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian] What are you supposed to do WITH a maniacally depressed
robot?
[Marvin] You think you have problems? What are you supposed to do
if you ARE a maniacally depressed robot? No, don't try and answer,
I'm 50,000 times more intelligent than you and even I don't know the
answer...
- HitchHiker's Guide to the Galaxy
