[GRASS-dev] any way to know color assigned to a cell?
Michael Barton
michael.barton at asu.edu
Wed Apr 18 17:10:34 EDT 2007
Bob,
This is exactly what I need.
Michael
On 4/18/07 12:22 PM, "Bob Covill" <bcovill at tekmap.ns.ca> wrote:
> Michael,
> If you are looking to duplicate d.histogram why not use r.stats? This
> will output raster values with the percent or area which could be used
> for plotting a histogram. If this did work it could be modified to
> output the associated raster color along with the other values. Maybe I
> am missing the point?
> On a related issues I have used a modified version of r.stats for a
> while now to create equalized color bars for raster maps. You simply
> calculate the distribution over a set number of color breaks, drop a
> custom colortable over the breaks and apply with r.colors rules=.
> Hope this helps.
> Bob
> On Wed, 2007-04-18 at 09:30 -0700, Michael Barton wrote:
>> This is fine, but I'm afraid that it won't help planned implementation. This
>> is partly because I didn't phrase my question correctly. What I really need
>> to know is what color is assigned to a cat value. The idea is to do
>> histogramming in wxPython. It might be nice to have the histogram show the
>> map colors like d.histogram can. To do that, I need to know the color
>> assigned to a cat. However, to get colors by querying every cell in a map
>> with r.what would take a very long time.
>> Michael
>> On 4/18/07 7:05 AM, "Bob Covill" <bcovill at tekmap.ns.ca> wrote:
>>> On Thu, 2007-04-19 at 01:51 +1200, Hamish wrote:
>>>> Michael:
>>>>>>> If have a map with values from 0-255 I create a set of color rules
>>>>>>> such that
>>>>>>> 0% = green
>>>>>>> 100% = red
>>>>>>> GRASS will create a color table that will assign a nice gradient of
>>>>>>> colors from 0:255:0 to 255:0:0 to the values from 0-255.
>>>>>>> Is there any way when querying a single cell of that map to know
>>>>>>> what color has been assigned to it?
>>>> Glynn:
>>>>>> Set a 1x1 region around the cell, then r.out.ppm | pnmnoraw | sed.
>>>>>> Or r.mapcalc 'out = (r#map * 256 + g#map) * 256 + b#map', query the
>>>>>> composite map and decode the category number.
>>>>>>> Similarly, is there any way to know what color has
>>>>>>> been assigned to any value in the 0-255 range?
>>>>>> Set a 1x1 region, r.mapcalc "tmp = $value", r.out.ppm ...
>>>>>> Seriously; this is how d.rast.edit.tcl does it.
>>>>>> Yeah; we could probably do with a "r.what.colors" module.
>>>> Michael:
>>>>> I was contemplating a wxPython histograming module, like the TclTk
>>>>> profiling module, and liked the option in d.histogram of being able to
>>>>> use the color table for the histogram colors. But this seems like a
>>>>> pretty intensive batch of calculations to do it.
>>>> you could try "r.profile -c" with a profile which starts and stops at
>>>> the cell center (length=0). Also it should be very simple to add a flag
>>>> just like "r.profile -c" to r.what, if that helps.
>>> I have a version of r.what that I modified to optionally output RGB
>>> color. If interested I could commit to CVS?
>>> Bob
>>>> But probably the most direct solution is a SWIG-Python interface to the
>>>> libgis color-lookup fns themselves.
>>>> Hamish
>>>> _______________________________________________
>>>> grass-dev mailing list
>>>> grass-dev at grass.itc.it
>>>> http://grass.itc.it/mailman/listinfo/grass-dev
>> Michael Barton, Professor of Anthropology
>> School of Human Evolution & Social Change
>> Center for Social Dynamics & Complexity
>> Arizona State University
>> phone: 480-965-6213
>> fax: 480-965-7671
>> www: http://www.public.asu.edu/~cmbarton
Center for Social Dynamics and Complexity
phone: 480-965-6213
fax: 480-965-7671
