[GRASS-dev] nviz crashes on MacOSX
William Kyngesburye woklist at kyngchaos.com
Thu Apr 19 11:15:10 EDT 2007
Looks like for some reason it's using the system TclTk instead of the
one bundled in the GRASS app package.
Make sure your X11 build of TclTk got bundled in the app package.
It's possible the automatic detection of the TclTk prefix isn't
working for the bundling stage, like we discussed offlist, and you
would have to set TCLTKPREFIX before building GRASS.  If you used the
universal tcltk build instructions in the readme, then that would be /
usr/local/tcltk.
On Apr 19, 2007, at 8:24 AM, Agustin Diez Castillo wrote:
> After compiling and installing latest cvs following William's
> readme, I got this error when trying nviz (itt works fine when
> using his binaries):
> Date/Time:      2007-04-19 13:10:33.116 +0200
> OS Version:     10.4.9 (Build 8P2137)
> Report Version: 4
> Command: nviz
> Path:    /Applications/GRASS-6.3.app/Contents/Resources/etc/nviz2.2/
> nviz
> Parent:  wish8.4 [15392]
> Version: ??? (???)
> PID:    15397
> Thread: 0
> Exception:  EXC_BAD_ACCESS (0x0001)
> Codes:      KERN_INVALID_ADDRESS (0x0001) at 0x6e614320
> Thread 0 Crashed:
> 0   libX11.6.dylib       	0x005dacd2 XQueryExtension + 51
> 0x9ac47000 - 0x9acc5fff com.tcltk.tcllibrary 8.4.7 a	/System/
> Library/Frameworks/Tcl.framework/Versions/8.4/Tcl
> 0x9acdf000 - 0x9ad8efff com.tcltk.tklibrary 8.4.7 a	/System/Library/
> Frameworks/Tk.framework/Versions/8.4/Tk
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Oh, look, I seem to have fallen down a deep, dark hole.  Now what
does that remind me of?  Ah, yes - life."
- Marvin
