[GRASS-dev] etc file finder, take 2
Hamish
hamish_nospam at yahoo.com
Fri Apr 20 03:09:12 EDT 2007
> Hamish wrote:
> > > use GPATH_MAX as the size of the path buffer (I've
> > > been replacing various random constants with that value as I find
> > > them; also for GNAME_MAX and GMAPSET_MAX)..
> > more of a comment than a question-
> > "char input_map[GNAME_MAX];" is often used to hold input=map at mapset
> > name, when the array often should be able to hold "GNAME_MAX + @ +
> > GMAPSET_MAX + \0" = 514 chars.
> > GNAME_MAX is long enough (256, gis.h) that map at mapset should rarely
> > exceed that, but it's something to look out for.
> > Perhaps gis.h should also have G_FULLYQUALIFIED_MAX ?
Glynn:
> Who said that GNAME_MAX referred to the length of an *unqualified*
> name?
> It's just an arbitrary value used for array dimensions; nothing
> actually checks map names against that value.
/* File/directory name lengths */
#define GNAME_MAX 256
#define GMAPSET_MAX 256
#define GPATH_MAX 4096
if GMAPSET_MAX is 256, and GNAME_MAX should be able to hold name at mapset,
shouldn't GNAME_MAX be at least GMAPSET_MAX+2?
[2= 1 char long mapset name + @]
otherwise concat can theoretically overflow.
(playing devil's advocate here to make the allocs a little more bad-
assumption-proof)
Hamish
