[GRASS-dev] [grass-code P][372] scritps for converting raster
maps into GRASS 7 format, and back
Michael Barton
michael.barton at asu.edu
Sat Apr 21 12:58:35 EDT 2007
On 4/19/07 9:08 AM, "Glynn Clements" <glynn at gclements.plus.com> wrote:
> You shouldn't need pyOpenGL unless you're planning on making OpenGL
> calls from Python. The only parts of NVIZ which make OpenGL calls are
> Togl and do_zoom.c. NVIZ is just a UI; all of the actual work is done
> by the OGSF library.
So we don't need pyOpenGL to replace Togl? Does the wxPython GLCanvas
replace Togl? Somehow we need to make calls from wxPython event handlers to
actually display/render a 3D image. I'm totally in the dark as to how this
is done. I've worked with the UI part of NVIZ (this is the overwhelmingly
greatest part, as you point out), but don't understand how the OGL calls are
actually made.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
