[GRASS-dev] Re: numeric-numpy-scipy for graphs?
Michael Barton
michael.barton at asu.edu
Tue Apr 24 01:25:53 EDT 2007
Should we go ahead and set this in the rendering section of the TclTk and
wxPython code? Do we need to turn it off after each rendering?
Michael
On 4/23/07 2:08 AM, "Glynn Clements" <glynn at gclements.plus.com> wrote:
> [BTW, on the subject of perfomance: I've extended the PNG driver to
> support writing 32-bpp BMP files. More significantly, if you set
> GRASS_PNG_MAPPED=TRUE, it will immediately write out the file, then
> mmap() for use as its framebuffer, so it doesn't have to explicitly
> write the file after each command.]
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
