[GRASS-dev] [grass-code I][383] v.what bug: only reports on first
coordinate pair
grass-codei at wald.intevation.org
Wed Apr 25 17:13:37 EDT 2007
code I item #383, was opened at 2007-04-25 23:13
Status: Open
Priority: 3
Submitted By: Markus Neteler (markusn)
Assigned to: Nobody (None)
Summary: v.what bug: only reports on first coordinate pair
Issue type: module bug
Issue status: None
GRASS version: CVS HEAD
GRASS component: vector
Operating system: Linux
Operating system version:
GRASS CVS checkout date, if applies (YYMMDD):
Initial Comment:
The v.what command only reports for the first coordinate pair:
GRASS 6.3.cvs (spearfish60):~ > v.what fields east_north=599121.75,4922981.125,604768.125,4916050.125
East: 599121.75
North: 4922981.125
Map: fields
Mapset: PERMANENT
Objekttyp: Fläche
Quadratmeter: 652908.220
Hektar: 65.291
Acres: 161.333
Sq Miles: 0.2521
Layer: 1
Category: 21
-> here should be a second report.
Markus
PS: have fixed odd param order in v.what in CVS right now.
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=383&group_id=21
