[GRASS-dev] Re: [GDAL] #1587: Error compiling gdal-grass against gdal 1.4.1
Wed Apr 25 20:21:26 EDT 2007
Markus Neteler wrote:
> it is currently no more possible to compile the official
> GRASS-GDAL-OGR plugin against GRASS 6.3-CVS. There is
> a bug report open at GDAL:
> http://trac.osgeo.org/gdal/ticket/1587
> In summary, there a certain function definition needs
> to be conditionalized upon the GRASS version but there
> is the problem that it is defined as char in
> include/version[.in].
> Following question is open:
> >  Reporter:  perrygeo     |        Owner:  mloskot
> >      Type:  defect       |       Status:  reopened
> >  Priority:  normal       |    Milestone:
> > Component:  ConfigBuild  |      Version:  1.4.1
> >  Severity:  normal       |   Resolution:
> >  Keywords:  grass        |
> > Comment (by mloskot):
> >  Markus,
> >  Would it be possible to have version definition as a preprocessor macro
> >  instead of character object?
> >  Ideally, I think it would be best if there is a version macro defined as a
> >  number calculated as:
> >  MAJOR * 100000 + MINOR * 100 + MICRO
> >  what for '''6.3.0''' results as '''600300'''.
> >  This way we have a value that can be easily calculated from version string
> >  and makes it very easy to compare if one version is lower/higher from
> >  another one.
> >  What do you think?
> > Ticket URL: <http://trac.osgeo.org/gdal/ticket/1587#comment:7>
> > GDAL <http://trac.osgeo.org/gdal/>
> > Geospatial Data Abstraction Library is a translator library for raster and vector geospatial data formats.
> Please suggest - the result should then be posted into the
> GDAL bugtracker (you need to register for this, see trac).
I've changed version.h.in so that GRASS_VERSION_* are preprocessor
definitions.
[BTW, we need to decide if GRASS_VERSION_RELEASE is an integer or a
string. AFAICT, it's the actual release number for releases and "cvs"
for the CVS version.]
However, this won't help with previous versions. You could use e.g.
	#include <grass/version.h>
	#ifdef GRASS_VERSION_MAJOR
which will succeed in current versions and fail in older versions.
Alternatively, you can use the following in the Makefile;
	include include/Make/Grass.make
	-DGRASS_VERSION_MAJOR=$(GRASS_VERSION_MAJOR)
But that may not work with non-GNU make utilities, and including the
*.make files is a relatively recent change.
