[GRASS-dev] broken API
Maciej Sieczka tutey at o2.pl
Fri Apr 27 06:31:14 EDT 2007
Markus Neteler wrote:
> The question is if the change keeps backwards compatibility for
> GDAL, QGIS and other applications which rely on this file.
Since gdal-grass plugin fails to build with 6.3 CVS too, will r.out.gdal in
6.3 CVS work when I build the plugin against 6.2.2 CVS, and keep both 6.2.2
and 6.3 installed?
Maciek
View this message in context: http://www.nabble.com/broken-API-tf3650628.html#a10216768
Sent from the Grass - Dev mailing list archive at Nabble.com.
