[GRASS-dev] ps.map: how to rotate paper?
Fri Apr 27 17:46:58 EDT 2007
Markus Neteler wrote:
> I wanted to create a landscape-A3 map but cannot figure out
> how to rotate the paper (-r doesn't do what I want).
Add a new paper size with the width and height swapped, e.g.
    { "a3-landscape", 16.535, 11.693, 1.0, 1.0, 0.5, 0.5 },
If you want to print it, you'll need a printer which accepts
A3-landscape paper (i.e. an A2 printer).
