[GRASS-dev] ps.map: raster always under vector map?
Fri Apr 27 17:49:15 EDT 2007
Markus Neteler wrote:
> it also appear here that a raster map is always drawn under the vector
> map even when defining the raster map as first in the psmap config
> file.
> Can anyone confirm?
That's correct.
Bear in mind that the raster map is always opaque, so it will obscure
anything which is drawn beneath it. Level 3 PostScript supports masked
images, but ps.map doesn't make use of this.
