[GRASS-dev] problem with r.colors on Mac
Michael Barton
michael.barton at asu.edu
Sun Apr 29 15:25:23 EDT 2007
On 4/17/07 9:39 PM, "Glynn Clements" <glynn at gclements.plus.com> wrote:
> Michael Barton wrote:
>> It's the progress bar.
>> If I comment out the following lines in Gronsole::output_to_gronsole, it
>> stops crashing. It's something about one of the two lines that execute after
>> progress reaches 100%.
>> # } elseif { [regexp -- {^GRASS_INFO_PERCENT: (.+)$} $str match val
>> rest] } {
>> # Gronsole::progress $path $ci $val
>> # if { $val >= 100 } {
>> # Gronsole::progress $path $ci -1
>> # $outtext insert $mark "\n" $tags
> My first would guess would be the progress bar widget itself.
> It may be best to simply trace the code, e.g.:
> proc tracer {cmd op} {
> puts stderr $cmd
> trace add execution Gronsole::progress enter tracer
> Redirect stderr to a file; it will generate a lot of output.
> FWIW, I found that the first time that I ran "r.colors --ui ...", the
> UI crashed, but I couldn't reproduce it after that, which suggests
> that it's timing related, i.e. it happens if the module produces
> output too fast. I note that wish takes quite a while to start the
> first time, but is much quicker thereafter (when the files are in
> RAM).
> Does it help if you remove the "update" call from the end of
> ProgressBar::_modify?
I have a bit of down time to try again to track down this problem. It
crashes the GUI when any process is run that takes a bit of time and
generates a progress bar (e.g., r.stats too).
Where is ProgressBar::_modify??
It doesn't seem to be in gronsole.tcl
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
