[GRASS-dev] ps.map: raster always under vector map?
Markus Neteler
neteler at itc.it
Mon Apr 30 03:09:16 EDT 2007
Glynn Clements wrote on 04/27/2007 11:49 PM:
> Markus Neteler wrote:
>> it also appear here that a raster map is always drawn under the vector
>> map even when defining the raster map as first in the psmap config
>> file.
>> Can anyone confirm?
> That's correct.
> Bear in mind that the raster map is always opaque, so it will obscure
> anything which is drawn beneath it.
That's exactly what I need: in my case the raster map contains a few
cells only,
but I need it on top to not be covered by vector contour lines etc.
> Level 3 PostScript supports masked
> images, but ps.map doesn't make use of this.
Maybe ps.map's raster command needs an additional parameter "ontop" or
something like this? Hacking C code as Hamish suggests might be asked too
much for the average user.
Markus
ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
ITC -> since 1 March 2007 Fondazione Bruno Kessler
