[GRASS-dev] Parallelized raster computing: using r.li.daemon code?
Markus Neteler
neteler at itc.it
Thu Aug 2 06:43:48 EDT 2007
I wonder if the r.li.daemon code could be moved up to (some) library level
to
use parallelization whereever possible. Since the code is there and seems to
work...
Markus
View this message in context: http://www.nabble.com/Parallelized-raster-computing%3A-using-r.li.daemon-code--tf4205362.html#a11962114
Sent from the Grass - Dev mailing list archive at Nabble.com.
