[GRASS-dev] Re: [GRASSGUI] module dialogs in wxPython
Mon Aug 6 12:18:16 EDT 2007
Michael Barton wrote:
> What would it take to have a module come up in the wxPython version of the
> autogenerated dialog if GRASS_GUI is set to wx in .grassrc6? I think this
> discussion got started sometime back, but wasn't resolved.
It needs:
1. A Python equivalent of lib/gis/gui.tcl.
2. A Python equivalent of generate_tcl(), unless you make #1 accept
XML, in which case G_usage_xml() can be used.
3. Some changes to G_gui() to select the desired GUI based upon
$GRASS_GUI.
#1 is the main part; the rest is straightforward.
