[GRASS-dev] zomm issue with wx GUI
Carlos "Guâno" Grohmann
carlos.grohmann at gmail.com
Tue Aug 7 04:58:45 EDT 2007
I'm missing the bitmaps in man pages as well.
I'm also missing the 'overwrite' option (only tried r.in.gdal)
Carlos
On 8/7/07, benjamin.ducke at ufg.uni-kiel.de
<benjamin.ducke at ufg.uni-kiel.de> wrote:
> I can confirm both these issues (on Gentoo Linux).
> If I leave a wx monitor open, after I quit GRASS, I will
> not be able to close it at all and have to kill the underlying
> process. If however, I also leave the main manager window open,
> then I will be able to close that and it will in turn close
> open map windows, even if I exited the GRASS shell already.
> I observe the same problem with zooming.
> Additionally, the manual pages in the wx module dialogs do not
> show any bitmaps. But this may be a problem with my own wxPython
> setup.
> Benjamin
> > Just been paly around with the wx gui. Works fine, but there are some
> > issues:
> > if I hit crtl+d inthe terminal (as I usually do to exit grass), the
> > gui remains open. and if I exit the gui (file-exit) the grass session
> > remains open in the terminal.
> > BTW, I am using it as the main gui, called from .grassrc6
> > Now the main one. If I set the zoom to some map, I don't get the whole
> > map in the display! see the pictures to compare what happens in wx and
> > tcl guis
> > http://www.igc.usp.br/pessoais/guano/temp/tcl.jpg
> > http://www.igc.usp.br/pessoais/guano/temp/wx.jpg
> > (I put the images in this server because I'm not sure whats the limit
> > for the dev list, although they are quite small)
> > Carlos
> > Carlos Henrique Grohmann - Guano
> > Visiting Researcher at Kingston University London - UK
> > Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
> > Linux User #89721 - carlos dot grohmann at gmail dot com
> > _________________
> > "Good morning, doctors. I have taken the liberty of removing Windows
> > 95 from my hard drive."
> > --The winning entry in a "What were HAL's first words" contest judged
> > by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
> > Can't stop the signal.
> > grass-dev mailing list
> > grass-dev at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grass-dev
_________________
