[GRASS-dev] Re: wx init.sh needs updating
William Kyngesburye woklist at kyngchaos.com
Tue Aug 7 13:13:04 EDT 2007
On Aug 7, 2007, at 12:44 AM, Michael Barton wrote:
> I started messing around with a python replacement for init.sh,
> just to see
> what is needed. It is going pretty well, but tedious. Once done (and
> probably won't work right off) it could be a good opportunity to
> clean up
> the start up script for GRASS. Thinking ahead to a time when the
> same script
> can start GRASS on all platforms.
> Michael
Yeah, I just noticed a another oddity in init.sh related to wx - the
gui dependency test is still based on X.  While wxpython on other
'nix platforms may need X, it doesn't on OSX, and probably not on
Windows either.  Summarized:
if DISPLAY set (though it may be set but no X is available, at least
on OSX)
   test gui dependency - python for wx, wish for tcltk
   if it fails
     warn that *wish* doesn't work (oops)
else
   no gui possible
   if a gui is set
     warn that *X* is not available, and there a gui is not possible
(oops again)
Instead of testing the gui dependency first, maybe this should test
the gui setting first:
case GRASS_GUI:
   tcltk, etc)
     test X availability
     or better, ignore DISPLAY and test only wish - if it works, X is
implied, or whatever graphical base needed (this would take care of
native tcltk implementations, like Aqua or Windows, not that they
work well)
   wx)
     test python availability (X implied if needed - as long as
python works)
...just some thoughts...
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"We are at war with them. Neither in hatred nor revenge and with no
particular pleasure I shall kill every ___ I can until the war is
over. That is my duty."
"Don't you even hate 'em?"
"What good would it do if I did? If all the many millions of people
of the allied nations devoted an entire year exclusively to hating
the ____ it wouldn't kill one ___ nor shorten the war one day."
<Ha, ha> "And it might give 'em all stomach ulcers."
- Tarzan, on war
First Pogril: Why is life like sticking your head in a bucket filled
with hyena offal?
Second Pogril: I don't know.  Why IS life like sticking your head in
a bucket filled with hyena offal?
First Pogril: I don't know either.  Wretched, isn't it?
-HitchHiker's Guide to the Galaxy
