[GRASS-dev] GRASS 6.3.0 release preparation
massimo di stefano massimodisasha at yahoo.it
Sat Aug 11 19:58:10 EDT 2007
i'm using 6.3-cvs on osx
i compile it every 2-3 day on osx
i found a problem running d.nviz from the gis.m button (fly trhough
path for NVIZ)
when press the related button i've this log :
can't read "xmonlist": no such variable
     while executing
"lindex $xmonlist 0"
     (procedure "guarantee_xmon" line 16)
     invoked from within
"guarantee_xmon"
     (procedure "Gm::fly" line 3)
     invoked from within
"Gm::fly"
     ("uplevel" body line 1)
     invoked from within
"uplevel \#0 $cmd"
     (procedure "Button::_release" line 18)
     invoked from within
"Button::_release .mainframe.topf.tb1.bbox4.b1"
     (command bound to event)
runnig d.nviz directly from command line everyting works fine.
to check if it is related to my ststem configuration
i've compiled grass 6.2 using the same dependancie that i use for 6.3
release
and i've that in grass-6.2
d.nviz works fine using the gis.m button
nice to see that a7.0 is coming :-)
really thanks to all developpers!!!
Massimo Di Stefano
Il giorno 11/ago/07, alle ore 23:05, Helena Mitasova ha scritto:
> On Aug 11, 2007, at 4:14 AM, Markus Neteler wrote:
>> Hi,
>> I think that it is time to get out a GRASS 6.3.0 release
>> (as sort of technology preview). It would be great to
>> have it ready for FOSS4G2007, say, September.
>> IMHO, GRASS 6.3-CVS is in a good shape. Thoughts?
> Before the release, can somebody please double check that the
> following works
> (most of this I believe was already discussed and should be fixed):
> - nviz: you can add additional surfaces using the Raster surfaces
> panel without crashing nviz
>   (please try different resolutions, spatial extent, mapsets)
> - nviz: mask the displayed surface using a selected raster map from
> within nviz (in my version the
> mask only masked the displayed vector data)
> - nviz: save state - you can save the state and then load it and
> you can start working where you
>   stoped when you saved your state
> - nviz: when saving the image, that the actual displayed image is
> saved rather than redrawn image
> (for example if you have loaded 4 surfaces and you display only one
> of them the automatic redraw
>   during the saving procedure would display all four)
> - nviz: file sequencing tool saves the entire path rather than just
> the name of raster maps which
>   nviz then cannot interpret when you try to play the script
> I hope that most of this has been already fixed but generally I
> have a 4 months old nviz on Mac
> having more capabilities fully functional than my few weeks old
> version on RedHat Linux,
> so it would be good to test before releasing.
> Otherwise GRASS63 is probably in better shape and more
> systematically tested than any
> previous release as both Markus and I ran almost all GRASS commands
> (not with all options though)
> and although there has been some level of frustration, most things
> work very well.
> If you ask me what was the most annoying (but not critica) thing
> that I have found when using
> GRASS under a deadline - then it was the large default size of the
> centroid symbol in d.vect.
>  I had to go through large number of vector data when preparing the
> new data set
> and each time I forgot to set the size smaller I got the unreadable
> mess of overlapping crosses.
> So if we could change the default to something smaller - perhaps
> size 2 rather than 5,
> that would be great, because most of the time you really want to
> see your polygons
> not the centroids and they are quite visible at size 2 even with my
> old eyes
> (maybe make the default red as the default fill is grey). This was
> already
> discussed some time ago too.
> Helena
>> Markus
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20070812/82c78c39/attachment.html
