[GRASS-dev] [grass-code I][458] 6.2 modules using new parser flags
Maciej Sieczka tutey at o2.pl
Sun Aug 12 08:04:10 EDT 2007
code I item #458, was opened at 2007-08-11 16:28
Status: Open
Priority: 2
Submitted By: Scott Mitchell (smitch)
Assigned to: Nobody (None)
>Summary: 6.2 modules using new parser flags
Issue type: module bug
Issue status: fixed in CVS
GRASS version: 6.2
GRASS component: display
>Operating system: all
Operating system version:
GRASS CVS checkout date, if applies (YYMMDD):
>Comment By: Maciej Sieczka (msieczka)
Date: 2007-08-11 22:44
Message:
I have checked current 6.2 CVS source and I can find no occurences of
--q or --v flags in use by any modules.
BTW however, I have noticed that GEM already uses it's own --q flag
(for --query, not for --quiet). I'm curious if this could cause any
problems for the parser and if it should be changed. Apllies to both
6.2 and 6.3.
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=458&group_id=21
