[GRASS-dev] v.what compiling error
Michael Barton michael.barton at asu.edu
Fri Aug 24 02:22:10 EDT 2007
Well, I just updated and recompiled from the cvs and v.what won't compile.
I'll list the error below.
Michael
Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
========= v.what compile error ===============
cmb-MBP:~/grass_dev/grass6/vector/v.what cmbarton$ make clean
rm -rf OBJ.i686-apple-darwin8.10.1
gcc -I/Users/cmbarton/grass_dev/grass6/dist.i686-apple-darwin8.10.1/include
-g -O2    -I/Library/Frameworks/GDAL.framework/unix/include
-DPACKAGE=\""grassmods"\"
-I/Users/cmbarton/grass_dev/grass6/dist.i686-apple-darwin8.10.1/include \
        -o OBJ.i686-apple-darwin8.10.1/main-1.12work.o -c main-1.12work.c
        -o OBJ.i686-apple-darwin8.10.1/main.o -c main.c
        -o OBJ.i686-apple-darwin8.10.1/what.o -c what.c
gcc -L/Users/cmbarton/grass_dev/grass6/dist.i686-apple-darwin8.10.1/lib
-DPACKAGE=\""grassmods"\" -o
/Users/cmbarton/grass_dev/grass6/dist.i686-apple-darwin8.10.1/bin/v.what
OBJ.i686-apple-darwin8.10.1/main.o OBJ.i686-apple-darwin8.10.1/what.o
-lgrass_display -lgrass_gis -lgrass_datetime -lz     -lgrass_raster
-lgrass_pngdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lz
-L/Library/Frameworks/FreeType.framework/unix/lib -lfreetype  -liconv
-L/Library/Frameworks/UnixImageIO.framework/unix/lib -lpng  -lz
-lgrass_psdriver -lgrass_driver -lgrass_gis -lgrass_datetime -lz
-lgrass_gis -lgrass_datetime -lz      -lgrass_driver -lgrass_gis
-lgrass_datetime -lz     -L/Library/Frameworks/FreeType.framework/unix/lib
-lfreetype  -liconv  -lgrass_gis -lgrass_datetime -lz       -lgrass_raster
-lfreetype  -liconv  -lgrass_gis -lgrass_datetime -lz      -lgrass_vect
-lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz      -lgrass_dbmiclient
-lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz      -lgrass_gis
-lgrass_datetime -lz      -lgrass_dgl -lgrass_dig2 -lgrass_gis
-lgrass_datetime -lz     -lgrass_rtree  -lgrass_gis -lgrass_datetime -lz
-lgrass_linkm -lgrass_rtree  -lgrass_dig2 -lgrass_gis -lgrass_datetime -lz
-lgrass_rtree  -lgrass_dgl -lgrass_rtree -lgrass_linkm -lgrass_dbmiclient
-lgrass_datetime -lz      -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz
-L/Library/Frameworks/GDAL.framework/unix/lib -lgdal -lgrass_form
-lgrass_datetime -lz      -lgrass_gis -lgrass_datetime -lz
-lgrass_dbmiclient -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz
-lgrass_gis -lgrass_datetime -lz      -lgrass_dbmibase -lgrass_gis
-lgrass_datetime -lz       -lgrass_gis -lgrass_datetime -lz      -lz
/usr/bin/ld: multiple definitions of symbol _main
OBJ.i686-apple-darwin8.10.1/main-1.12work.o definition of _main in section
(__TEXT,__text)
OBJ.i686-apple-darwin8.10.1/main.o definition of _main in section
(__TEXT,__text)
/Users/cmbarton/grass_dev/grass6/dist.i686-apple-darwin8.10.1/lib/libgrass_r
tree.dylib(gammavol.o) definition of _main
/usr/bin/ld: warning multiple definitions of symbol _init_color_table
/Users/cmbarton/grass_dev/grass6/dist.i686-apple-darwin8.10.1/lib/libgrass_p
sdriver.dylib(Color_table.o) definition of _init_color_table
ngdriver.dylib(Color_table.o) definition of _init_color_table
/usr/bin/ld: warning multiple definitions of symbol _true_color
ngdriver.dylib(Graph_set.o) definition of _true_color
sdriver.dylib(Graph_set.o) definition of _true_color
/usr/bin/ld: warning multiple definitions of symbol _file_name
ngdriver.dylib(Graph_set.o) definition of _file_name
sdriver.dylib(Graph_set.o) definition of _file_name
/usr/bin/ld: warning multiple definitions of symbol _height
ngdriver.dylib(Graph_set.o) definition of _height
sdriver.dylib(Graph_set.o) definition of _height
/usr/bin/ld: warning multiple definitions of symbol _width
ngdriver.dylib(Graph_set.o) definition of _width
sdriver.dylib(Graph_set.o) definition of _width
/usr/bin/ld: warning suggest use of -bind_at_load, as lazy binding may
result in errors or different symbols being used
symbol _init_color_table used from dynamic library
sdriver.dylib(Color_table.o) not from earlier dynamic library
/Applications/Grass/GRASS-6.3.app/Contents/Resources/lib/libgrass_pngdriver.
collect2: ld returned 1 exit status
make: ***
[/Users/cmbarton/grass_dev/grass6/dist.i686-apple-darwin8.10.1/bin/v.what]
Error 1
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20070823/abd6cc5d/attachment.html
