[GRASS-dev] compile directions
William Kyngesburye woklist at kyngchaos.com
Fri Aug 24 12:42:02 EDT 2007
Hmm, but it doesn't explain the importance of those actions when
there are compile problems - either when recompiling (or restarting
an aborted compile) the same source or updated CVS source.  Casual
users (or casual developers) might not realize that either of these
could help.
Maybe add a note in section (G) Update of Source Code? (or add it as
a step in the detail)  Possibly also add a general notes section with
this hint? (since it could also apply to recompiling/restarting
compilation)
On Aug 24, 2007, at 11:27 AM, Patton, Eric wrote:
> There are instructions in the INSTALL file distributed with Grass
> on the difference between the two:
> make clean - delete all files created by 'make'
> make distclean - 'make clean' + delete all files created by './
> configure'
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
First Pogril: Why is life like sticking your head in a bucket filled
with hyena offal?
Second Pogril: I don't know.  Why IS life like sticking your head in
a bucket filled with hyena offal?
First Pogril: I don't know either.  Wretched, isn't it?
-HitchHiker's Guide to the Galaxy
