[GRASS-dev] Re: [GRASS-user] GRASS6.3 on Windows
Michael Barton
michael.barton at asu.edu
Sat Aug 25 01:45:28 EDT 2007
On 8/24/07 2:59 AM, "Hamish" <hamish_nospam at yahoo.com> wrote:
> Michael Barton wrote:
>> Anything else GUI-wise broken and fixable that anyone has noticed?
> Before 6.3.0 is released I'd like to finish off this wish:
> Lat/Lon locations should format the Map Display statusbar x,y string into
> 45°59.9999'S 170°59.9999'W, not as decimal -45.999999 170.999999.
> http://wald.intevation.org/tracker/index.php?func=detail&aid=401
> (I had previously committed code to reformat non-lat/lon coord text to a
> steady
> '%.3f'; I just left lat/lon as '%.6f' or so but feel that's unfinished)
> I have an idea or two how to do this slightly more efficiently than the
> suggested code in the wish report (ie a few less lines in the mouse movement
> update loop), but maybe the CPU overhead per mouse movement isn't as bad as I
> expect and I'm stuck in a 4MHz 8086 mentality.
> Feel free to have a stab at it if you like; I filed it as a wish as I was
> having trouble finding the time to implement it, but didn't want it abandoned.
> By the same token, I'd like it to be in 6.3.0 as that may be the last chance
> for new TclTk features to be widely used.
> There remains an unanswered question if "\xB0" produces a degree symbol on all
> platforms.
This is one reason I haven't pursued this. The other is that for many GIS
uses, decimal degrees are easier to work with than degrees minutes
seconds--even though the latter might look nicer.
> test:
> $ echo puts "90\xB0" | wish
I tried this and it didn't work. Nothing printed in the wish screen. But it
may be the test rather than the \xB0 code. Also need to try on Windows.
Michael
> Hamish
> ______________________________________________________________________________
> ______
> Fussy? Opinionated? Impossible to please? Perfect. Join Yahoo!'s user panel
> and lay it on us. http://surveylink.yahoo.com/gmrs/yahoo_panel_invite.asp?a=7
Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
